psiburr 0 Posted March 19, 2010 I've done a search but couldnt find the answer... A week ago after a 20 min motorway drive the oil warning light and intermittent buzzer came on. Checked the oil (forgot for a while and I know the my mod'ed G60 should be checked regularly) and it was just below the cross hatching.Topped the oil up. Yesterday the buzzer sounded once with no light, oil level was fine. today at the same point of the same drive home as the previous 2 times the oil light and buzzer came on. Again the oil level is top of the hatching and the coolant is clear ?! what go'on ? :confused4: Quote Share this post Link to post Share on other sites
Toad 0 Posted March 19, 2010 The light and buzzer are for the oil pressure, not the level! You should stop driving it and get the oil pressure checked ASAP! Quote Share this post Link to post Share on other sites
psiburr 0 Posted March 19, 2010 if the level is fine, where could the pressure be loosing ? Quote Share this post Link to post Share on other sites
Toad 0 Posted March 19, 2010 Knackered bottom end bearings, knackered cam bearings. Broken oil squirter, knackered oil pump, oil pump gasket/bolts gone. Could be all sorts of things. Quote Share this post Link to post Share on other sites
psiburr 0 Posted March 19, 2010 What other symptoms should I look for ? Quote Share this post Link to post Share on other sites
Toad 0 Posted March 19, 2010 You just need to find out what the actual oil pressure is. Quote Share this post Link to post Share on other sites
psiburr 0 Posted March 19, 2010 hmm, sounds expensive. thanks for the info, i'll get on it asap. Quote Share this post Link to post Share on other sites
