jma 0 Posted April 6, 2010 Hi I seem to have a problem, when I start the car it seems to be running lumpy/misfiring. What should I be doing to to diagnose the problem? your help is apperciated. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 6, 2010 What varient mate vr,g60,16v,8v?? Quote Share this post Link to post Share on other sites
jma 0 Posted April 7, 2010 Sorry it a VR6, it splutters sometimes idles normaly. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 7, 2010 Lumpy misfiring when warming up usually indicates weak fuelling. Check / replace the blue temp sensor and go from there. Also clean out the idle valve in case it's sticking open. Quote Share this post Link to post Share on other sites
jma 0 Posted April 7, 2010 kevhaywire said: Lumpy misfiring when warming up usually indicates weak fuelling. Check / replace the blue temp sensor and go from there. Also clean out the idle valve in case it's sticking open. Where is the blue temp sensor and idle valve? Quote Share this post Link to post Share on other sites
Toad 0 Posted April 7, 2010 Blue temp sensor is in the thermostat housing on the front right hand side of the engine, idle valve is the round thing plumbed in near the throttle body. Quote Share this post Link to post Share on other sites
jma 0 Posted April 7, 2010 Toad said: Blue temp sensor is in the thermostat housing on the front right hand side of the engine, idle valve is the round thing plumbed in near the throttle body. Can I change the blue temp sensor or do I need to take it to the mechanic? and how would I cleam the idle valve? Cheers Quote Share this post Link to post Share on other sites
