Grantham Red 0 Posted April 7, 2010 Newbie question so forgive me if it is a stupid one please. Have chanced into Corrado ownership so not fully up to speed with it all yet. I have a 1.8 16v. Its a 1990. It has vw service stamps up to 120000 and has now done 145k. The engine pulls very well and starts, ticks over, revs very well. No smoke popping or banging so all good. However it does make quite a loud tappet type noise at tickover that kinda comes and goes but is mostly there, hot or cold. Can I adjust the tappets on this engine and if so can anyone point me to some instructions? And if not adjustable what options do I have? Thanks Jon Quote Share this post Link to post Share on other sites
nemesis360 0 Posted April 7, 2010 You cant adjust the tappets as they are hydraulic. Replacement is the only option if they are the cause of the noise. Quote Share this post Link to post Share on other sites
Grantham Red 0 Posted April 7, 2010 OK But replacement of what? And is there anything else it might be? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 7, 2010 What oil are you using? - might be too thin A common trick is to add 1/2 a litre of ATF fluid to the engine for a couple on hundred miles before an Oil change, this seems to act like a flush Quote Share this post Link to post Share on other sites
Grantham Red 0 Posted April 7, 2010 10w 40 semi synthetic is that right? Quote Share this post Link to post Share on other sites
Grantham Red 0 Posted April 7, 2010 So back to how to stop the noise? Hydraulic cam followers yes? So Do i need to replace these? If so how difficult is that? Haynes manual stuff or what? Go on give a newbie a clue!??? Quote Share this post Link to post Share on other sites
carrots 1 Posted April 7, 2010 ive got the same problem with mine,i would like to know aswell :) Quote Share this post Link to post Share on other sites
Wullie 1 Posted April 7, 2010 It's reasonably covered in the Haynes manual for Golf and Jetta 84 to 92. Quote Share this post Link to post Share on other sites
Erny 0 Posted April 7, 2010 It's very common to have noisey tappets in krs, what's your oil level lookin like? if you do replace them soak the new ones in oil for a day or two to fill them up, otherwise there loud as fuck for a few hundred miles, Quote Share this post Link to post Share on other sites
Grantham Red 0 Posted April 7, 2010 Thanks' Erny etc. Oil Level spot on. Haynes manual here I come! Is it a difficult job? Quote Share this post Link to post Share on other sites
mrbeige 0 Posted April 7, 2010 Not a difficult job, but make sure you get the thing timed back up properly, as you will be removing the cams from the head, to do the tappets. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted April 7, 2010 AVS is the cheapest place i've found, on my to-do list but never gets to the top!! Obviosly you'll need 16 of them :( Quote Share this post Link to post Share on other sites
