Jim Bowen 1 Posted April 22, 2010 Before i go and buy one and attempt to fit it to cure leaking oil, is there anything important to know. Am hoping its a case of undo rocker cover, fit gasket, bolt everything back together. Quote Share this post Link to post Share on other sites
andy 0 Posted April 22, 2010 Yes its fairly simple but there are two types, depending on whether you have a plastic or metal cam cover. Quote Share this post Link to post Share on other sites
fla 9 Posted April 22, 2010 i would make sure you clean the rocker area where the gasket site thoroughly, use some instant gasket and take your time as you seat the gasket in there. Make sure the semi circles are pressed in properly. Then also apply instant gasket to the rocker cover, after having cleaned it well too. Carefull place the cover over the bolt pins and go around checking that the gasket has not moved. There's no oil pressure there as such, but somehow the oil manages to find the 'weak spot' in the seal and seap through. Its very straightforward, perhaps too much so, which is why i certainly had to redo my gasket after not sealing it well enough. Nuts are only tightened to around 20Nm, although someone can confirm teh correct rorque - basically not too much else teh rubber will just extrude out from the two faces. Quote Share this post Link to post Share on other sites
MattPc 0 Posted April 22, 2010 Torque for the cam cover bolts is 10 Nm Matt Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 22, 2010 nice one, thanks for the tips. am sure thats what is leaking on my engine. what cars had a plastic cover? mine is a 1995 VR Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 23, 2010 been to VW and ended up buying both types of gasket to save being wrong etc, they are only £12 each. I take it the sealent stuff is any old stuff from local garage type shop? Quote Share this post Link to post Share on other sites
beastie4126 0 Posted April 23, 2010 Normal instant gasket will do the job - just try and get black as it will look nicer than orange or blue :D oh and a 95 will probably have a plastic cover as mine does, a tap on the cam sprocet end should tell you. Quote Share this post Link to post Share on other sites
