Mawrick
Anyone got a picture of how the rubber around aux water pump
Searched around the net, to no avail.
Anyone have a picture of the water pump sitting in the to rubber "holders" ? I suspect the lower one is supposed to sit far down and over the bottom plastic part of the pump.
Also if anyone happen to have a detailed picture of the wiring around the starter/alternator area that would also be apreciated :)
thnx
i only have this pic, from when i got a gruvenparts bracket
looking at the marks on water pump am sure one sat right at the bottom and the other tight up under the plastic part.
Once you have the rubber lined up with holes where it mounts it should become obvious
Here are pix I took just now.
Starter, etc very difficult to get your nose or camera in there! If you are more specific perhaps can get a pic.
thnx guys, as I thought - it was a he**** trying to get it to fit over the plastic at the bottom - luckily when I looked thru some of the parts I'v bought for the car - and was going to fit the gruvenparts fuel line thingys I discovered that I also had that Gruvenparts thingy for the Water pump, so solved the problem in the end :)
