eugopnosaj 0 Posted May 5, 2010 As the title ive got a small oil leak coming from the dizzy on my valver, tried ECP for various oil seals etc but they can't find anything, having tried stealers yet. There is oil inside the cap and that is where it seems to be leaking from, its also melted the black plastic bit that sits inside the cap due to the leak, its made my gearbox all dirty now :( it was nice and tidy'ish in there before. Does anyone have the part numbers for the seals? or an idea about this problem. Will try and post pics soonish Thanks, Jay Quote Share this post Link to post Share on other sites
wormy 0 Posted May 5, 2010 Dunno if this is the seal you're after..? Can't think of any other seals around there.. A 9A (2.0 16v) should have distributor #1 on the attached image. And distributor #1 uses this seal: "027 905 261" :dorky: Seems to cost a bit from the stealers though, my guess would be somewhere around £10.. :cuckoo: Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted May 5, 2010 Cool thanks, there is also a plastic seal that sits between the main distributor and cap that i would also need to replace (as its melted) however it doesnt seem to be in the image you supplied, i will get an image uploaded and hopefully someone knows about it, or that it might even have the part number on it £10 seems a lot for an oil seal?! (need to get myself a copy of ETKA from somewhere...) Quote Share this post Link to post Share on other sites
wormy 0 Posted May 5, 2010 Cool thanks, there is also a plastic seal that sits between the main distributor and cap that i would also need to replace (as its melted) however it doesnt seem to be in the image you supplied, i will get an image uploaded and hopefully someone knows about it, or that it might even have the part number on it £10 seems a lot for an oil seal?! If the plastic seal doesn't show, that usually means that it isn't available as a separate part (anymore). Yes, I agree that it's alot, but ETKA shows it at "8.02" inc 18% vat, and from my experience the dealer always charges a tad more then that. Dunno if the price in my etka is in euro or gbp, but it usually gives a rough indication.. :shrug: Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 6, 2010 I got a seal for the dizzy when I bought a head gasket set. Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted May 6, 2010 I got a seal for the dizzy when I bought a head gasket set. i too bought a head gasket set so ill check to see if theres one there. not sure what to do about the plastic bit now though... Quote Share this post Link to post Share on other sites
wormy 0 Posted May 6, 2010 I got a seal for the dizzy when I bought a head gasket set. i too bought a head gasket set so ill check to see if theres one there. not sure what to do about the plastic bit now though... If the plastic bit is loose, then you could probably get it used from someone.. :-) Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 6, 2010 try club gti forum, info on there for stripping 16v distributor and where to get seals from (for a few pence IIRC) Quote Share this post Link to post Share on other sites
wormy 0 Posted May 6, 2010 Just remembered there's one more picture of the dizzy area.. Anything here? :shrug: Or does the 16v have the dist on the head..? Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 6, 2010 16v distributor is driven off the exhaust cam and is horizontal which makes it more prone to oil getting inside it, usually due towear in the shaft, not the seals alone though, best bet is a new/recon one as you get a new hall sender then too. Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted May 6, 2010 16v distributor is driven off the exhaust cam and is horizontal which makes it more prone to oil getting inside it, usually due towear in the shaft, not the seals alone though, best bet is a new/recon one as you get a new hall sender then too. So you reckon it would be better to buy a new one, would this include everything or just the distributor without the cap? How much am i looking at for a new one/recon one Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 6, 2010 I've seen complete ones (new/recon) on ebay for 50 quid or so, worth trying VW trade parts too, it might be on special offer and a similar price. Pretty much all are recon/exchange even the VW ones. Quote Share this post Link to post Share on other sites
Wullie 1 Posted May 6, 2010 I had the same problem several years ago and ended up getting a new dizzy. Tried a lot of things, normal and innovative with the old one but never stopped the oil leaking. Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted May 6, 2010 I had the same problem several years ago and ended up getting a new dizzy. Tried a lot of things, normal and innovative with the old one but never stopped the oil leaking. Hmm, looks like thats my only option really, ill see what ive got in the way of seals in the gasket set and see if that resolves the issue but i do need the plastic but as it is preventing the cap from clipping in properly... might just bite the bullet.... http://cgi.ebay.co.uk/VW-GOLF-JETTA-PASSAT-CORDOBA-TOLEDO-DISTRIBUTOR-NEW-/170477263683?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27b13c9b43 Quote Share this post Link to post Share on other sites
