holeinmk1
Special tools for 16v?
Hi just wonderng if i need a special tool to replace the timing chain on a 16v kr? If so is it the sort of thing i could get from GSF etc, if not where?
Cheers ears :D
Tom
theres no chain on a 16v? only the one on the cams. that doesnt need any special tools, nor do you need special tools for the belts
a timing belt tensionner tool helps (like a spanner but with two lugs to fit into the tensionner), as does a timing belt tension setting tool.
But neither are essential, angled long nose pliers do the job and you can guess the belt tension by twisting butween you finger and thumb.
...angled long nose pliers do the job and you can guess the belt tension by twisting butween you finger and thumb.
I cut the middle prongs off an old dinner fork and bent the outer pins over = The perfect cam tool!
Ghetto-style!
:norty:
