Kempy 0 Posted May 29, 2010 Does anybody know if they are the same or do I need a KR dizzy for my KR head. The rest of the KR is a 2.0l 9a.... thanks. Currrently got my 9a dizzy on my KR head and its not firing? thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 29, 2010 they most certainly are, part no. 051 905 205C Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 29, 2010 i thought i'd solved my problem there. I think i'm gonna have to try the dizzy off my daily Quote Share this post Link to post Share on other sites
billy_whizz 0 Posted May 29, 2010 are you sure your igniton switch is not dead as we had that one and it was the switch Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 29, 2010 dunno, does that make the spark? Quote Share this post Link to post Share on other sites
billy_whizz 0 Posted May 30, 2010 no but its quite common to loose power to the coil when the switch is dead Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 30, 2010 there is 12v going to the coil and around 9v leaving it when ignition is on Quote Share this post Link to post Share on other sites
billy_whizz 0 Posted May 30, 2010 but what about when cranking as thats when they loose power to the coil with a bad switch Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 30, 2010 i couldn't test that i was on my own, worth looking at that is it? Quote Share this post Link to post Share on other sites
billy_whizz 0 Posted May 30, 2010 the easiest way to check is to have the ignition on then pull the small wire from the starter the one withthe spring clip and run a wire from battey live to the connector on the starter where the small wire goes if it starts its the switch Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 30, 2010 to byepass the switch? Quote Share this post Link to post Share on other sites
billy_whizz 0 Posted May 30, 2010 yeah just for cranking as most times when you crank if the switch is bad it will cut the power for the coil Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 30, 2010 ok I'll give that a go. I hope thats it Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 30, 2010 the easiest way to check is to have the ignition on then pull the small wire from the starter the one withthe spring clip and run a wire from battey live to the connector on the starter where the small wire goes if it starts its the switch no joy trying that Also I managed to test the voltage from the coil whilst cranking and it was 10v? Quote Share this post Link to post Share on other sites
