Ginger60
CRANK BOLT
Hi does anyone know any good crank bolt / pulley combos to stop the wobble im getting again? I did the golf pully bolt mod about 5 years ago. Wobble started again but got it early this time!
On a G60? - just use the standard bolt that VW supply for that engine.
Hi that Darren? ok mate thanks for the tip :salute:
No sorry - I don't work for G-werks but Darren said a while ago that the new VW bolts are now ok to use - maybe you need a new pulley too though...
I'd give G-werks a call maybe and just confirm.
ok chap will do, godamn its a tight bolt though, wont shift. Need a industrius air gun...
yep, if it's been on a while or is the factory original a normal impact gun won't touch it.
Well in the end I got the car towed down to a local garage where the guy used an airgun the size of a small house :nuts:
Want one the thing was brilliant! Crank good...
Ordered new pulley, tensioner, bolt, belts and getting ali pulley re datummed at the engineers....
