rmn
Standard G60 injectors
Does anybody know the resistance rating and cc rate of the standard G60 injectors?
Thanks
Richard
is ther any benefit to fitting bigger injectors in a chipped G60??
Yeah, if you're running a smaller pulley with chip you start to get close to the upper limit of how much fuel that the original injectors can provide so run the risk of blowing your engine up due to running lean... Bigger injectors (higher flow, same physical size!) will solve this problem... 8)
