UseOnceDestroy 0 Posted August 18, 2010 I've lowered the C again and apart from the ride comfort being impaired, my chin spoiler splitting and the sump getting a minor scrape ... it's awesome!! :cuckoo: I'm a little paranoid about the sump taking more of a hit than a minor scrape, so was thinking ... is there any form of sump guard you can buy? Does anyone have any experience with them? Cheers :) Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 19, 2010 The problem wtih sump guards is they obviously sit lower than the sump so if your low you will be hitting it all the time. I had one on my old 4motion Golf which was quite low and it was a PITA to be honest. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted August 19, 2010 I've been wanting to get a sump guard made because at £180+ for one its a bit steep for a sheet of metal. I know I'd prefer to have a sheet of metal smacking on the ground relatively often than my sump on occasions. I hit my sump 3 times and the third time put a hole in it! Shows how strong these indestructible sumps are, and im not even that low! Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 19, 2010 The VR ones are ok as well, newer Al alloy ones crack very easily. There is the Mk5 R32 sump option as well remember. Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted August 19, 2010 Has anyone got a drawing for one? I should be able to make one at work. Quote Share this post Link to post Share on other sites
Erny 0 Posted August 19, 2010 Welded a thick plate to my vr6 one till I get a mk5 r32 one, then when the new one is tucked up a little higher I'll make a snug fitting skid plate allowing enough space for alittle engine movement, hopefully that combo should have the sump gaurd sat roughly where a normal vr sump would be. Anyluck Quote Share this post Link to post Share on other sites
Ben-B 0 Posted August 19, 2010 Would a custom-made shallow sump be ok with the standard pump, or would it need different oil pump in the sump? Quote Share this post Link to post Share on other sites
fla 9 Posted August 19, 2010 There is a gearbox guard on the auto - i removed it obviously for the conversion to manual but its a really hefty piece of metal! Might look into fitting it around the sump. If its ok, i'll post some pics up. Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted August 19, 2010 Strictly Dubs used to do one - contact Simon and see if they can still source them... You don't say what engine you've got but as I recall the SD one was for a VR6 Mark Quote Share this post Link to post Share on other sites
UseOnceDestroy 0 Posted August 24, 2010 Cheers for all your feedback, a friend of mine has had a custom one made for his scirocco by a local company ... Stronger metal and shallower, should hopefully do the trick! Quote Share this post Link to post Share on other sites
