lewis1982
ABS light
My ABS light comes on but wont go off....
dont know if this has anything to do with it, but it started not long after fitting my coilovers.
Anyone any ideas :confused4:
naa - really not sure if you could actually test it with resistance.
I would take a physical look at them first - maybe it's dirt between the sensor and "wheel" also.
If the wire have gotten "caught" by the new suspension it might even be ripped off. :)
They can be tested for resistance (just been through this on mine) and it's very easy to do. Typically the sensors should be about 1100-1200 ohms. The front ones can be tested from in the engine bay (connectors are on top of each suspension strut). The rear ones the connectors should be under the rear seats.
