hyland770
intake manifold removal
is this as rasy as i think it is, just tkae the throttle body off (if i can as the allen key heads are all rounded....cheers previous owner!) then undo the bolts and wip it off? i want to polish it all up to get under the bonnet look a bit nicer, any help appreciated cheers!
sorry, 1.8 16v....
put it in your sig then :)
the manifold is fairly easy to remove, couple of brackets support it at the back and then the nuts that hold it to the lower half at the front, you obviously need to move the ISV and injector line support brackets as they supported on those bolts.
Oh, and the vacuum pipe to the break servo at the back.
Get a (4 hole) new gasket for the two halves of the inlet join though, they tend to break up if they are not very new and your manifold will just leak air in.
