carrots 1 Posted October 12, 2010 the starter on my 1.8 16v kr has been playing up,ive got a new un on order and am wondering how hard it is to change.cheers Quote Share this post Link to post Share on other sites
dragon green 5 Posted October 12, 2010 It's one of the easiest jobs to do ! 10 -15 minutes max, i didnt even disconnect the battery,just make sure the main starter lead is tied out of the way, Good luck Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted October 12, 2010 It's one of the easiest jobs to do ! 10 -15 minutes max, i didnt even disconnect the battery,just make sure the main starter lead is tied out of the way, Good luck Don't suppose it's as simple on a G60 is it? I need to do this soon as the solenoid has gone on my starter Quote Share this post Link to post Share on other sites
dannyboy 0 Posted October 12, 2010 id disconnect the battery,sods law what would happen if it didnt. :shock: yeap its a easy job like DG said Quote Share this post Link to post Share on other sites
dannyboy 0 Posted October 12, 2010 easy on a g60 too alex.just bit more fiddly with boost pipes and fan in the way but just as easy Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 12, 2010 err, don't forget to support the engine, the starter bolts hold the front engine mount bracket on! Quote Share this post Link to post Share on other sites
dannyboy 0 Posted October 12, 2010 and that :lol: Quote Share this post Link to post Share on other sites
carrots 1 Posted October 12, 2010 cheers so a jack under the engine should do the job Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 12, 2010 cheers so a jack under the engine should do the job be gentle, put a lump of wood between the jack and the sump :) Quote Share this post Link to post Share on other sites
carrots 1 Posted October 13, 2010 cheers for that ,just hope a jack and wood will fit because the car is so low Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 13, 2010 cheers for that ,just hope a jack and wood will fit because the car is so low bit of a faff, but it might be easier to put the front of the car on axle stands under the front sills/rear subframe mounts first and then put the jack unde rthe engine, that would give you easy access to the lower starter bolt from underneath then too. Quote Share this post Link to post Share on other sites
