vw domo 0 Posted October 25, 2010 I went to order some new oil pressure senders from vw today and they couldn't find the part numbers on there system for the blue or yellow senders, instead came up with a clear/white for the high pressure and i think it was black for the low pressure sender, both with a slightly different part number. for the low pressure sender the limits where higher than 0.3 bar as well so im wondering if this is right? do they not sell the VAG blue and yellow senders anymore? Quote Share this post Link to post Share on other sites
Reggit 0 Posted October 25, 2010 Blue and yellow sensors are the water temperature ones aren't they? Quote Share this post Link to post Share on other sites
vw domo 0 Posted October 25, 2010 Blue and yellow sensors are the water temperature ones aren't they? i hope not, because one of them has an oil leak lol the senders on top of the oil filter housing im on about. Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 25, 2010 The specific value isn't that important and the parts have changed over the years anyway, you just need one around 0.3 and one around 1.8 bar I think, it's only for the warning when pressure drops off really badly from the pump so as long as the bar rating is within 10% or so it should be fine. They should be able to tell you if the part no. you have on the part in your hand is obseleted though :scratch: Quote Share this post Link to post Share on other sites
vw domo 0 Posted October 25, 2010 The specific value isn't that important and the parts have changed over the years anyway, you just need one around 0.3 and one around 1.8 bar I think, it's only for the warning when pressure drops off really badly from the pump so as long as the bar rating is within 10% or so it should be fine. They should be able to tell you if the part no. you have on the part in your hand is obseleted though :scratch: thanks davidwort, there was no part number on the old ones, just a pressure rating. must be aftermarket :scratch: i think when he searched the system it came up with the newer ones, which i questioned. Quote Share this post Link to post Share on other sites
vw domo 0 Posted October 31, 2010 fitted the new senders today and i get the oil light flashing so there defo not right, think the low presure sender is rated 0.75 - 1.25 which is nowhere neer what it should be. :? vw will probably make a big fuss about returns as well. Quote Share this post Link to post Share on other sites
Toad 0 Posted October 31, 2010 From ETKA. White and Black are definitely the wrong combo, I'm sure I got a blue one for the VR recently enough. Quote Share this post Link to post Share on other sites
vw domo 0 Posted October 31, 2010 thanks toad, just had a look and the low pressure one is 068 919 081 c 0.75 - 1.05 and this was the one he was directed to on the system when i asked for the blue sender. the high pressure one is the 056 919 083 1.6 - 2 that you have on your list there. not sure if thats even right as the one on there at the moment has no details on it. Quote Share this post Link to post Share on other sites
vw domo 0 Posted November 5, 2010 vw had an update and the computers where messed up, got the right ones now :D Quote Share this post Link to post Share on other sites
