jonrb 0 Posted October 26, 2010 Simple and quick question. I think the Heater Matrix on my 1995 Corrado VR6 is leaking (classic signs of misting up and smelling of coolant). I've been offered a Heater Matrix from a Mk2 Golf by a colleague. Will this fit or does the Corrado use a different part? Cheers Jon Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 26, 2010 it will fit, but don't use a mk2 part, you want a mk3 matrix which is stronger, it's the mk2 ones that VW fitted by-pass valves to the feed and return hose, to prevent them exploding if the system became blocked or over-pressurised. Quote Share this post Link to post Share on other sites
big ben 10 Posted October 26, 2010 get the valeo heater matrix from GSF, same as what has lasted 15 years and think £30 Quote Share this post Link to post Share on other sites
jonrb 0 Posted October 26, 2010 davidwort said: it will fit, but don't use a mk2 part, you want a mk3 matrix which is stronger, it's the mk2 ones that VW fitted by-pass valves to the feed and return hose, to prevent them exploding if the system became blocked or over-pressurised. Hmmm. Dilemma as my colleague only wants beer money for the mk2 part. Thanks for the info though! Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 26, 2010 brand new? if it's genuine VAG and brand new then don't turn it down, otherwise get a new pattern mk3 one. Quote Share this post Link to post Share on other sites
Portent 0 Posted October 26, 2010 Surely for such a pain in the arse to fit item you only want to do it once so just get a new one rather than a spare old used one. Quote Share this post Link to post Share on other sites
jonrb 0 Posted October 26, 2010 Seems it's used (it's come out of a Mk2 Golf that was broken for spares) and it's still in its housing. So it's a toss-up whether to use it or the pattern part. I could spend as much labour on getting it out of its housing as the price difference between it and the new part. Edit: And as Portent says, the majority of the cost is going to be labour so I should probably get the new part. Quote Share this post Link to post Share on other sites
rado2 0 Posted October 26, 2010 i done this job last year and although not to difficult a real long process get a new one its worth it in the end . Quote Share this post Link to post Share on other sites
Neokitz 0 Posted October 26, 2010 Brand new ones from VAG are ridiculiously expensive. GSF matrix is a much better option and they are pretty good as well. Not a job i want to do more than once. Quote Share this post Link to post Share on other sites
jonrb 0 Posted October 26, 2010 Neokitz said: Brand new ones from VAG are ridiculiously expensive. GSF matrix is a much better option and they are pretty good as well. Not a job i want to do more than once. It's cost vs benefit though, isn't it? Let's face it, these are old cars now and at the age where you begin to wonder if replacement parts will outlast the car (or at least your ownership of it). However, I agree - the GSF one is the way forward. The second-hand Mk2 item will be a false economy and the VAG one an unjustifiable extravagance. Quote Share this post Link to post Share on other sites
big ben 10 Posted October 26, 2010 make sure you get the valeo though, the cheaper chinese version has been known to crack within weeks :shock: Quote Share this post Link to post Share on other sites
jonrb 0 Posted October 26, 2010 big ben said: make sure you get the valeo though, the cheaper chinese version has been known to crack within weeks :shock: Eeeps! :shock: Quote Share this post Link to post Share on other sites
jonrb 0 Posted October 26, 2010 Incidentally, GSF quote £50 all-in for the part (#178VG0041 - manufacturer not stated). ECP are £29 all-in with free delivery, part # 214440011 and, again, manufacturer not stated. Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 26, 2010 best thing to do is go down to a store and get them to dig the part out, valeo label=good, chinese writing=bad :( Quote Share this post Link to post Share on other sites
big ben 10 Posted October 26, 2010 i paid £37 for a valeo matrix i think, there was one for about £22 Quote Share this post Link to post Share on other sites
