vw domo 0 Posted November 16, 2010 had a look through the search and can only find info on the vr engine mount upgrades, like the mk2 diesel gearbox mount and poly bush mounts for instance. is this the same fitting for the valvers? need to go for some stiffer mounts really, is it worth doing them all? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 16, 2010 The 16v mounts are different, apart form the GB mount. Vibratechnics are your best bet. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 17, 2010 I think you can get heavy duty ones, normally labelled so or perhaps Diesel. I had a Diesel mk2 golf front mount one mine, and the whole cabin shook when the starter cranked over! :D Quote Share this post Link to post Share on other sites
vw domo 0 Posted November 17, 2010 thanks guys, il have a look into it and see what the best options are, not up for to much cabin vibration :lol: iv been to gfs already but the oil filled rear mount they offered seemed quite soft. Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 17, 2010 I personally wouldn't fit anything other than standard mounts on a valver, anything else seems to transmit a lot of noise and vibration even if it's just an uprated front mount (which is the one that gets the most strain on it) Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 17, 2010 I had a VT front and rear mount on my 16v, and it was fine... Quote Share this post Link to post Share on other sites
