Rams 0 Posted November 19, 2010 I found a small part and wasnt sure if its from my car or not? Took the timing covers off and double checked and everything was as it should be but im paranoid about it.... Does anyone recognise it? Quote Share this post Link to post Share on other sites
Bullfinch 0 Posted November 19, 2010 Looks like a pizza carton - probably not Quattro Formaggio as that is what Audi uses :nuts: Quote Share this post Link to post Share on other sites
krnau 0 Posted November 19, 2010 Bullfinch said: Looks like a pizza carton - probably not Quattro Formaggio as that is what Audi uses :nuts: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: in my gf's Probe, several of these came out of the timing belt cover. may not be the same for the corrado, just a thought Quote Share this post Link to post Share on other sites
Torsten 0 Posted November 19, 2010 did you find it inside or outside your corrado ?? Quote Share this post Link to post Share on other sites
VR6 0 Posted November 19, 2010 If I were you I wouldn't even start the car until that is properly replaced. Quote Share this post Link to post Share on other sites
Dr. Robotnik 0 Posted November 19, 2010 Looks pretty serious. Quote Share this post Link to post Share on other sites
fla 9 Posted November 19, 2010 might be the stepped spacer from the oil sump gasket, or a bolt locating guide? Quote Share this post Link to post Share on other sites
stu37 0 Posted November 19, 2010 Hello mate I believe this is a an insert that goes in a recess in the plastic cover to stop the pressure of a bolt or nut snapping of cracking the plastic.... as in bolt.... sleeved washer.... Plastic... :D Quote Share this post Link to post Share on other sites
swiftkid 1 Posted November 19, 2010 Its 'O' from a polo... or the insert in the plastic cover over the engine as stu said Quote Share this post Link to post Share on other sites
Rams 0 Posted November 19, 2010 Found it on the floor near my engine..... clutch, fly wheel, timing all checked and cant find where this part goes. Theres no step on the oil sump, its just a gasket and lots of bolts. 26 in fact. Checked all the engine mounts etc.... I had posted in my members thread that 2 bolts were missing that go through the head hasket and hold together the top timing chain cover.... My mechanic had a big carton of spare nuts and bolts and can only assume it got mixed up in there when looking for 2 bolts to secure the cover correctly. If anyone has any pics of location that would be great otherwise, its going to do my head in! I know what you mean, its a slieve of sorts but I just want to make sure. P.S It was good pizza! Quote Share this post Link to post Share on other sites
G60_edge 0 Posted November 19, 2010 sleeve for the one of the bolts that hold the gearbox cable bracket to the top of the gearbox? They go through a rubber mount. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 19, 2010 Had a bolt fall out from the holes in the wishbones and doesnt seem to have affect anything :lol: Just forget about it. Quote Share this post Link to post Share on other sites
law262 0 Posted November 19, 2010 Quote Hello mate I believe this is a an insert that goes in a recess in the plastic cover to stop the pressure of a bolt or nut snapping of cracking the plastic.... as in bolt.... sleeved washer.... Plastic... :D I second that. Quote Share this post Link to post Share on other sites
Rams 0 Posted November 19, 2010 Cool, cheers guys I will let you know if and when I find where it goes Quote Share this post Link to post Share on other sites
Rams 0 Posted November 19, 2010 You were right.... it was the gear linkage! My mechanic was happy and it was missing..... This forum is the best! :clap: Quote Share this post Link to post Share on other sites
Rams 0 Posted November 20, 2010 G60_edge said: sleeve for the one of the bolts that hold the gearbox cable bracket to the top of the gearbox? They go through a rubber mount. Well done that man Quote Share this post Link to post Share on other sites
stu37 0 Posted November 20, 2010 Good luck, I hope you find out where it goes, It is such a horrible feeling when you have spares left or find parts... I rebuilt my girlfriends brothers honda CRF 250 engine replacing everything, when finished he produced this SHIM.... he had found on the floor when it had been stripped... FU*CK F*CK F*CK!!!! Quote Share this post Link to post Share on other sites
Rams 0 Posted November 20, 2010 Found where it went, gear linkage! Posted above, You must have been more concious being the car was a relative! Next time I will put all parts in sections on nice white linned and label. Quote Share this post Link to post Share on other sites
stu37 0 Posted November 20, 2010 Tell me about... slowly growing feeling of wanting to be sick... ). Well done mate, I bet you feel relieved! Quote Share this post Link to post Share on other sites
