Blondie1 0 Posted January 18, 2011 Ok What to do? Ive had this nightmare high idle problem for several months now, a couple of mechanics have looked at it but not really helped. One plugged it into a computer and it read something about throttle body wiring, but he couldnt sort it. Anyway I got a code reader, plugged it in and it read 00516 Closed throttle body position sensor, so I thought yay simple change that. Mechanic picked the car up this morning, just phoned and said the code reader I had was a bit vague, and he thinks changing the throttle body and injection unit (whatever that is...) should sort the problem out... but this is already the 2nd throttle body on the car, my previous mechanic put a 1.8 one put on as you can adjust the idle on those, didnt really help..... So... do I stick with what the fault code reader said and just try changing the switch.... Im totally lost on what to do next :( Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 18, 2011 My guess is a wiring fault of some kind in the loom, you need either a good auto electrician to trace things or another car to swap bits over from to rule things out. A lot of basic tests can be made on individual components, resistance on sensors, physical movement of metering unit, injector flow, pressure, spray pattern, check lambda, fuelling, ignition side of things. physical and observational checks on wiring condition, electrical connectors. 9A engines don't have the best diagnosics and can be difficult to fix by modern methods of read code and replace items, they need more of a mechanical, systematic approach as they are so basic. Quote Share this post Link to post Share on other sites
adolf1976 0 Posted January 18, 2011 i suffered with idle probs too. Changed isv three times .throttle bodie cleaned then replaced. Still not joy. Seemed lumpy on idle. Then had bit of luck out scrapyard and found a passat took metering head off it paid a tenner swopped it over and problem sorted. Wicked try that mate Quote Share this post Link to post Share on other sites
Blondie1 0 Posted January 18, 2011 Oo ok, erm wats a metering head? Lol I hope it's not a wiring problem :( Quote Share this post Link to post Share on other sites
easypops 8 Posted January 19, 2011 The search is where you need to be.........but i'll save you the stress this time :D , lots of good links in this post, if you read the 'Kangaroo' one there is a brief description of how i solved the bad idle on my old valver.........bad wiring to the throttle potentiometer(which could be similar to your fault??).....happy reading :salute: viewtopic.php?f=1&t=100255&hilit=2.0+16v+idle Quote Share this post Link to post Share on other sites
Blondie1 0 Posted January 19, 2011 I have searched but I kinda get lost in it all and dont know which way to turn with it lol. Im not sure now whether to get a metering head, and a throttle body, see if that sorts it, or get someone to check the wiring.... Quote Share this post Link to post Share on other sites
easypops 8 Posted January 19, 2011 I know how you feel........when i had the bad idle, i replaced the fuel pump, distributor, leads, metering head, throttle potentiometer(throttle positioning switch), throttle body, ignition switch.....and is still did it :bad-words: .........i found the fault by chance, the wires to the tps were burst inside the plastic coating, they looked ok but were burst inside........keep at it, you'll get there :) Oh and most of the things i replaced before i found this forum......wish i had found it earlier :D Quote Share this post Link to post Share on other sites
Blondie1 0 Posted January 19, 2011 lol its doin my head iiiin lol. Right... think Im going to find an auto electrician, basing it on the fact that the two faults that have come up (one on computer and one on little code reader) have been throttle body wiring, and TPS. When I had my head gasket done the other week and mentioned it to the bloke, he said he plugged somet in on the throttle body that was unplugged and he thought that would solve it, so Im guessin he meant the throttle position sensor.... clearly didnt solve it so must be fooked lol. *sigh* I hate spending money I don thave when it might not fix the problem grrr lol x Quote Share this post Link to post Share on other sites
easypops 8 Posted January 19, 2011 There are 2 small vaccum hoses which attach to the underside of the rubber bit that goes onto the throttle body, one comes from the side of the airbox.......it wont run well if these aren't on Quote Share this post Link to post Share on other sites
Blondie1 0 Posted January 19, 2011 Ok I will check that later :D Quote Share this post Link to post Share on other sites
adolf1976 0 Posted January 20, 2011 the metering head is what sits on top of the air box can stick shut or open a bit when worn it controls the flow of petrol to injectors Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 20, 2011 check and double check every vacuum hose and joint as well as all the rubber and plastic sections and pipes that are part of or linked to the inlet system, worth squeezing the inlet hoses etc and spraying some brake or carb cleaner around them to see if it changes the idle/revs at all, if it does, the spray is getting sucked in through a leak somewhere. Quote Share this post Link to post Share on other sites
Blondie1 0 Posted January 20, 2011 oo ok will try that :) thanks :) Quote Share this post Link to post Share on other sites
farrantino 0 Posted January 20, 2011 I also had this problem replaced all the vacuum hoses and VAVA VOOOOM :D Quote Share this post Link to post Share on other sites
