hyland770
DIY Camber
Anyone done it?
I've heard that if you put a 1mm washer in between the lower bolts in between the stubaxel and rear beam you can adjest your own camber to get that "euro look" i wondered if anyones done this before? and if so is there any pics?
you shouldn't need to correct the rear camber, usually something is bent, but if you are doing it to give enough negative camber to be really visible and for show, then it's best left to that, just show, and preferably trailored to the show and back, rear wheel bearings wont last 5 mins and I'd imagine the handling could go really odd too.
to be fair the bearings will probably be OK, they're just not designed for running with a lot of camber, just expect them to need replacing now and then, but then they seem to need that on a lot of cars anyway :)
