Alex_G60_Fanatic 0 Posted February 9, 2011 Will the front cross member and slam panel from an early 16v corrado fit onto a early G60? Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 9, 2011 IIRC the slam panel and subframe should be fine, however depends how 'early' early is. The early 'rados didnt have PAS so if you get one like i did without PAS you'll have to drill holes in it Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 9, 2011 All Corrado's had PAS! Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted February 9, 2011 All Corrado's had PAS! Mine certainly does at any rate... Thanks Yan, looking at another Corrado being broken on SVAG but she's a 16V so thought I'd better ask :) Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 9, 2011 All Corrado's had PAS! Whoa! Hmmm wonder where mine came from then....got it off of __Andy__ on here Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 9, 2011 Hmmm wonder where mine came from then....got it off of __Andy__ on here You are refering to the radiator support panel, not the slam panel or cross member. The valvers dont have the extra cooling tube in the rad support panel for the PAS as they didn't need it, the PAS hoses are just routed closer to the block. Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 9, 2011 ah yes my mistake, i had to replace both parts which was where i just got confused :S and they do have the extra pipework that go through the panel...check out my pics at the end of the first post http://the-corrado.net/showthread.php?52083-Pre-mot&p=675686#post675686 Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted February 9, 2011 You are refering to the radiator support panel, not the slam panel or cross member. The valvers dont have the extra cooling tube in the rad support panel for the PAS as they didn't need it, the PAS hoses are just routed closer to the block. I was thinking of buying this as well TBH... But I also need to replace the PAS Pipes as mine are leaking.. I have a replacement Steering Rack off an old G60 but is it a problem to use the 16v support panel? I have no problems cutting or drilling it to fit the power steering rack... so long as it bolts on to the car without to much fuss. :) Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 9, 2011 Yeah, ditto PAS cooler pipes on my panel also. But mine is a derivative part number of what is on the car (letter change at end of number IIRC) so may be from a late 16v. The one which doesn't have holes in will be a mk2 Golf/ Jetta one. The parts are identical apart from little changes like that (although don't use a mk2 golf subframe). Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 9, 2011 I think the slam panel is a little different because of where the rad goes? may be wrong Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted February 9, 2011 if you find out where you get your power steering pipes from please do tell! The dealers is well far to expensive ! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 9, 2011 ebay mainly. Quote Share this post Link to post Share on other sites
