QuasiRob 0 Posted February 19, 2011 Hi, I have to fit a new radiator fan switch to my M reg VR6. I've got the new switch, I've found where it goes at the bottom of the radiator...how do I get the old one out?! I've taken the battery out but there isn't room to get an adjustable wrench around the switch. How did anyone else do it? The nut part of the switch would fit a 28mm spanner. Quote Share this post Link to post Share on other sites
emu 0 Posted February 19, 2011 Try from the bottom of the car. Last time I did it I had bumper and front panel removed from the car but was changing radiator at this same time so don't know if it's possible without removing this two things. Quote Share this post Link to post Share on other sites
SamG40 0 Posted February 20, 2011 I managed it from the top easy enough and thats with aircon. You just need to use the right length extension bar to clear stuff for the wrench. It shouldnt be that tight in there so should only need a couple of goes on the wrench to loosen it sufficiently. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 21, 2011 i can't get to mine for ****, been trying for ages, am taking rad out to do it when i get around to it, but only as i want to clean everything up anyway Quote Share this post Link to post Share on other sites
QuasiRob 0 Posted February 21, 2011 (edited) Still can't get to it, I'm now looking for a box spanner (28mm I think) as there should be enough room for the width of that, though might have saw the end off to make it short enough to be able to get it on. Can't use a socket cos of the length of the plastic bit on the end. Edit - it actually seems to be a 1 1/8 inch (1.125) nut, 29mm might also work. Edited February 21, 2011 by QuasiRob Extra information Quote Share this post Link to post Share on other sites
QuasiRob 0 Posted February 23, 2011 Finally got it out by cutting enough of the plastic part away with a hacksaw that I could get a 1 1/8 inch socket over it and unscrew it. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 23, 2011 i've broken the plastic on mine and can't even get the wired socket off the bit in the rad now :lol: Quote Share this post Link to post Share on other sites
SamG40 0 Posted February 23, 2011 Ah after re-reading I remember I bought a special socket from GSF to do this. They sell a thermo switch socket that is deep enough to fit over the plastic plug. Quote Share this post Link to post Share on other sites
