lion
breaking my corrado :(
Began to break my early rado in helious blue
2.0 abf bare block (bottom end going) 150
Black dash and insert 50
Grey interior 100 inc door cards
Grey trim, tunnel , underdash bits 50
Sebring alloys 2 good tires 125
Early clocks 170000 25
g60 driverside hub 40
Standard rear lights 50
all red rears 50
Red and light smoked rears 1 side damaged 40
Late black bonnet 50
merc rims £500
2 window mechs , loom and unit to convert manual to automatic 150 I can help fit
Thanks.
Everything collected from nw London, or we can try arange something
Edited by lion
more/less added
Could I take the bracket that holds the power steering fluid by the washer bottle container. It attaches to the wing
Rams
Hi,
Do you have the restraining bracket and bolt for the rear seats? Just in case, its located behind the rear seats at the bottom where the seats meet.
Thanks
Rams
Sorry I'm keeping everything under the bonnet for now
Hi,
Thanks
I've used them when I transferred the leathers into mine, sorry
Hi,
Thanks
Hi there would you be willing to cut out a couple of small sections from the shell for me please?. I have pictures of the areas i need if your willing.
UK not sure about that , but ill let u know
