Marshall936
Help valver playing up!
When i start the valver it revs up to 2,000 revs and then drops down and cuts out? was working fine a week ago and the only thing i can think of is that i unplugged a hose to move the airbox and forgot to reattach it before starting the car. (its reattached now but now the above problem occurs...) pic of hose attached. Any help appreciated. thanks.
That is just a breather tube. Take it off again and check it isn't blocked somehow!
Sent from iPhone 4 using Tapatalk
have you disconnected another vacuum hose (by accident) or something in the process? sounds like you have a lot of unmetered air getting into the inlet after the metering head/airflow plate
There's a short fat link hose underneath the main intake pipe that can be easily dislodged as it's not secured by clips. Would cause your symptoms if it's been dislodged.
