carrots 1 Posted April 13, 2011 my standard exhaust always sounds like its blowing untill it gets warm,ive had a realy good look at it on a ramp and cant see anywhere its leaking.its not long had new mainifold gaskets due to a knackerd head.my mate had a mk3 golf the same aswell.wouldnt mind a stainless sometime,i will have to read some threads on here about um Quote Share this post Link to post Share on other sites
tony_ack 0 Posted April 13, 2011 Metal expands when hot - just a thought but maybe there's a leak at one of the joints or gaskets at ambient temperature, but the metal expands to plug the leak when hot? If the manifold gasket has just been changed, then that may be a suspect! Quote Share this post Link to post Share on other sites
carrots 1 Posted April 13, 2011 it was doing it with the old gaskets aswell Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted April 13, 2011 Sounds daft but could it be the cat ? Mine makes a chuffing kinda sound cant really explain it better than that but once its warm it usually sounds alot better Also if its one of the joints making yhe noise like said above till its warm i used a product called chemical metal to seal the gap works a hell of a lot better than gum gum Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 13, 2011 I wouldn't really recommend Chemical Metal, seeing as it's only guaranteed up to 149 degrees Celcius....and you're using it on one of the hottest parts of your car. Quote Share this post Link to post Share on other sites
carrots 1 Posted April 14, 2011 havent got a cat and its def not blowing anywhere,its strange Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 15, 2011 my stainless is up for grabs. bolts straight up to a 4 branch. give me a yell if youre interested. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 15, 2011 Usually a cracked manifold does this - seals itself up when hot Quote Share this post Link to post Share on other sites
carrots 1 Posted April 15, 2011 could be,its going to have to stay like that then lol Quote Share this post Link to post Share on other sites
