MikeVR6
Wanted: few little bits - Breakers please look
To make my car complete. I need a few small bits.
- Rear number plate plinth
- Rear number plate light trim
- Bonnet stay complete and uncorroded
- Radiator/Fan plastic cowling with "Achtung Heisse!" sticker
- RHS Instrument Cluster screw cover
Hi i can help with the no plate plinth & the light trim,poss the stay & the cluster screw cover ,will check them
Thanks rod
Thanks for the info on the stickers and numberplate plinth.
Let me know Rodmax. I'd really like to get these bits sorted.
Hi mike,
I do have the light trim ,the plinth is good (no splits or broken edges) but the small tubes on the rear are broken,it was held on with doublesided no plate tape.apart from that it's fine.i'm affraid the bonnet stay does have corrosion on it.But i do have the right hand cluster screw cap !!.
So id like 20 pounds for the plinth 5 pounds for the light trim & 10 pounds for the screw cover (i know these are no longer available & very hard to find,i have seen them going for 3 times that ,so i think thats a fair price for it) If you are interested let me know & i will get a cost for the postage
thanks rod
Think I might have a good - Bonnet stay complete and uncorroded - somewhere in the depths of the garage. Still has the little rubber ring on it too and I do have a - RHS Instrument Cluster screw cover - in a box somewhere.
Hi Rod - I'll take those bits from you. Chuck in the bonnet stay too? Just let me how much the postage is.
Shaun - thanks for getting back to me. But Rod has the bits ready to go by the sounds of it.
Ok no worries ,you can have the bonnet stay.will get you a price for postage.
thanks rod
think i have the cowling trim - will check - if so £10 posted?
Tim
Hi Tim. If you have it complete with the stickers, screws and any little clips on top for the bonnet stay?
Maybe not £10 though as it has to be posted to Germany. Probably £15.
