P3rks
G60 4 into 1 Manifold - Touching rubber steering boot
I've just fitted a 4 into 1 manifold to my G60 and the manifold just touched the rubber boot on the steering column. I don;t want any fires so what can you recommend?
I don't really want to heat wrap the manifold, to avoid cracks etc.
I have some heat proof matting which is good up to 600°C... But if I wrap this around the rubber boot, then this touches the manifold even more.. Would this withstand the heat?
Pics:
Any other options I can go for?
Also.. Does any one know the correct torque for the copper bolts?
Send it back? Clearly doesn't fit properly!
It's a LHD manifold, like the majority of them, so most sit like this. I've done a search to confirm this, I've just not found a confirmed answer on what to do.
Anyone? I'd like to put my car back together at the weekend and I want this tackling first. . :o
have you tried taking the rubber boot off to have a look how much space there is between the rubber and the lower steering column cv joint inside it? you might be able to push the rubber boot in a bit to give you more space to fit a heat shield.
How much space do you have between your Cam cover and bonnet? Can you raise your engine alittle to possibly gain space? You can lay a load of blue tack on your cam cover to get a bonnet imprint, and use a hockey pucks and longer bolts, and if your cars lowered your cv joints will be alittle happier too.
I think this will be my plan.. cable tie it in.. Wrap it in the solder mat which is good for about 600°C.. Then metal cable tie that.. Hope it works..
This is not a bad shout actually.. I'll have a look, but i;m sure the manifold doesn't have much clearance where it passes the bulkhead.
Thanks for the idea's guys.. Keep 'em coming! :thumbleft:
