nommie 10 Posted August 5, 2011 (edited) Went out for a drive tonight... put my fullbeam head lights on; they worked for a split second and went back off again. So i checked my upgraded loom and the fuse was melted. So i took it out and replaced it but still no fullbeam. I get side lights and dipped but when on dipped and pull for fullbeam it goes to side lights. Can anyone help with this? i all so dont get the blue light on the dash. Edited August 5, 2011 by nommie Quote Share this post Link to post Share on other sites
Wild-Animal 0 Posted August 6, 2011 If there are relays next to your fuse that you replaced then it might be worth replacing it, they uprated headlight kits are often bad for moisture affecting them on the fuses and relays, once you have it fixed wrap your relays and your fuses in isolation tape to stop moisture getting in, be careful wrapping your fuses so you can still get access to them Quote Share this post Link to post Share on other sites
benzo_26 10 Posted August 7, 2011 I had the exact same thing happen last week. Two relays, fuses and fuse holders sorted it. Water caused the corrision. Good luck Quote Share this post Link to post Share on other sites
tony_ack 0 Posted August 7, 2011 Happened to me last week too... must be that time of the month! Quote Share this post Link to post Share on other sites
