Ralphead 0 Posted August 13, 2011 The pas oil reservoir on my '90 16v has ATF - 0L stamped on it so I was quite happy to fill it with ATF but I stumbled upon the owners manual and it says to use G 002 000. The chap in my local factors says my car is from around the changeover date so he can't be sure which to recommend. Help, please, quick. They shut in an hour. Thank you Quote Share this post Link to post Share on other sites
RW1 0 Posted August 13, 2011 (edited) VW don't specify ATF for the Corrado. Its always been stated as G 002 000. No distinction with 1989 - 1995. G002 000 is a pale green fluid. Otherwise it will be ATF Dexron. . Edited August 13, 2011 by RW1 Quote Share this post Link to post Share on other sites
carrots 1 Posted August 13, 2011 ive got the green stuff in mine Quote Share this post Link to post Share on other sites
Vw.bones 10 Posted August 13, 2011 Yep G002 green stuff all the way.......... Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 14, 2011 Yep, the early 16v cars even have red ATF fluid reservoir caps even though a green version is available, all I can think is karmann simply used all the mk2 pas bits. Green hydraulic fluid is definitely the stuff for even these early cars though. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 14, 2011 It's now G 004000 you need, £5 from VW and 1 bottle is enough for the car Quote Share this post Link to post Share on other sites
Ralphead 0 Posted August 14, 2011 Thanks for the help. Sorry I've been so slack replying. I bought a bottle of G 002 000 compatible stuff figuring I could take it back on Monday if it wasn't right. My pump went caput (two days after an afternoon of machining spacers to get the damn pulleys aligned) and the fluid was brown so I had nothing to go on. The new (to me) pump is off a 2 litre and so is ever so slightly different so it's back to the lathe for another spacer. I'll look in to the G 004 000. It's cheaper than what I bought.. Quote Share this post Link to post Share on other sites
