owen g60 10 Posted August 21, 2011 Hi, I have terribles wheel wobble and a clunking noise when steering... i have had the front end apart today and my top mounts are shot. can anybody recommend where would be best to get them from, i have checked and GSF and Euro car parts both have them. There are also a few on ebay that say they will fit. any other suggestions are welcome. Regards, Owen Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 21, 2011 4 cylinder up to 1994, or vr6 and late 4 cyl? Pattern bits can vary wildly in quality but vag bits will be 4 times the cost for early one piece mounts. Quote Share this post Link to post Share on other sites
owen g60 10 Posted August 21, 2011 1992 G60 PG engine code... have found a set from euro car partshttp://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_1.8_1992/p/car-parts/suspension-and-steering/suspension/suspension-mounting/?669440320&1&e8a423ed33f0f210b64d615c896b14484309a4cb&000872 and a set on ebay http://www.ebay.co.uk/itm/GOLF-MK2-3-PASSAT-MK2-3-FRONT-STRUT-TOP-MOUNT-MOUNTING-/120440088088?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c0ac9e618 both listed as fitting want to be sure im not buying crap parts to then have to replace again in a year or so Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted August 21, 2011 The SKF ones should be good, they make bearings for aircraft. Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 22, 2011 I wouldn't buy the e-bay ones simply because of the problem of returning anything that is faulty or fails early, GSF and ECP have always been very good at replacing faulty parts for me if anything does fail, and I have had good and bad results with pattern top mounts of that type, ultimately though if you plan to keep the car or have uprated suspension, VAG ones may be a worthwhile investment. Quote Share this post Link to post Share on other sites
owen g60 10 Posted August 22, 2011 i have replaced the passenger top mount and it is now solid... need to do the drivers one. will need the brass collar that bolts down onto the top mount... any ideas where to get one or if someone has one spare i will happily take it Quote Share this post Link to post Share on other sites
