ddubalicious
G60 Engine Rebuild or Replace?
Hi all,
We have a noise coming from the top of the engine, more noticeable when warm and only under slight engine load.
I have the car booked in for repair but I do not know if I should have the engine rebuilt or replaced with a recon engine?
I have looked for a recon engine but cannot seem to locate any.
Is there anyone reliable who can supply me with a good reliable recon engine?
Thanks ):
Only becuase you mention under load, my suspision is a loose manifold or a crack on it very close to the head....
I'd imagine if it was something to do with damaged valves, you' have running & starting issues, and camshaft and tappet noises are not really affected by engine load - more sensitive to RPM and temp.
Edited by andycowuk
slelpnig
I have an engine, needs a head gasket (drinking a bit of water), but other than that was fine for me.
Dont know where you are but im in leics if you want a butchers.
