tim20vt
vibratechnics/solid front mount?
anyone using these can tell me if you get alot more vibration im guessing you will with solid but how do the vibratechinics ones fair?
i need to replace mine, the standard type last pretty well considering the amount more power its running than standard so im just deciding what to get.
cheers
it's not just the vibration (that you will get), think of the poor driveshaft joints and the gearbox, a bit of engine mount movement cushions the rest of the drivetrain :)
I wouldn't go solid or race spec VT, but a road VT front mount should have enough movement to give a bit of isolation and probably only slight noticeable vibration at idle
I've got VT Gearbox and Rear engine, and a BlackForestIndustries Stage 1 front mount. Can't say I notice any extra vibration to be honest and it keeps keeps 375lb/ft in the bay daily so I can't complain!
Check out BFI, I think Regal Motorsport sell them in the UK and they are a lot cheaper than VT.
