deanjames
Engine bay Inpiration
I can show you mine which will inspire you to do nothing to yours :lol:
Seriously though, very nice mate. Have you painted the black bits silver?
my last two bays, first is still a work in progess, clean it all up and make it shiney, theyn replace all the bolts with stainless steel items
parts are anthracite i want to get samcos next and look at cleaning up bolts ect, may paint the waterbottle the same colour.
Swampy wheres the battery cover from
i had it made up for me by a local stainless steel fabricators, they made it from an off cut that would otherwise of being scrapped so it only cost me £15
as for the bolts, i now have a very good and cheap supplier, so if you can provide me with length, thread and size then i can supply nearly all the bolts in stainless steel or bright zinc plate
what is the underside of the battery cover like - my concern is the risk of shorting the battery?
it was just plain metal, but i got some rubber sheet and stuck it to the areas above the terminals.
the cover sat a good hlaf cm plus above the terminals
