dochy 0 Posted January 21, 2012 has anyone cleaned the boost pipes from the charger to the intercooler etc??what is the easiest and best way to do this??cheers. Quote Share this post Link to post Share on other sites
cptkirk 10 Posted January 22, 2012 if your on about wiping the crap off um, wd40 works a treat and makes um shine Quote Share this post Link to post Share on other sites
dochy 0 Posted January 22, 2012 its the inside of them!!looks like a bit of a cnut!!!bought a g60 with a foolked gharger and the inside is caked in bad oil!!need to clean before i put new charger in!! Quote Share this post Link to post Share on other sites
owen g60 10 Posted January 22, 2012 Disconnect them from the charger, throttle body and intercooler and remove from the car. Blast through with some degreaser and a jet wash Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
cptkirk 10 Posted January 22, 2012 i suppose carb or brake cleaner will blast it out no problem Quote Share this post Link to post Share on other sites
Wild-Animal 0 Posted January 22, 2012 If you have enough degreser you could try steep the pipes and intercooler in it over night. I know the gegreases I have used only really works if you work with a brush while using the degreaser. Quote Share this post Link to post Share on other sites
