big_mac
1.8 16V gearbox in a g60
hi guys my gearbox has finally gone into retirement, ive been offered a gearbox out of a 1.8 16v corrado but want to make sure the box will fit onto my g60 lump.
also is this gearbox well suited to the car?
and its a cable change box - is that any different from standard and if it is will this pose any problems?
thanks again guys
Andy
hello,
it will fit on fine and it is cable change, this is the set-up i have on my engine.
altho have have yet to drive it and dont know if the ratios are suited to the engine
big mac,
This should help, reckon no problem, let me know mate
Gear ratios with 5-speed manual:
16V to 92:
1st 3.40
2nd 2.12
3rd 1.44
4th 1.13
5th 0.91
Reverse 3.800
Final ratio 3.68
G60 1991-1992
1st 3.778
2nd 2.105
3rd 1.345
4th 1.034
5th 0.838
Reverse 3.800
Final ratio 3.647
Cheers
BigEastsideVWG60
thanks again guys
Andy
Well if you do decide to take it on buddy and this other box falls through then give me a pm cos i've got one sitting in my garage and its fully mint, i only took it off and bought another one cos i thought it was buggered, turned out it was the inner cv joints :mad:
anyway let me know
thanks again guys
Andy
I'd stick with the G60 box if possible as it's ratios are suited to the torquey nature of the engine whereas the 16V box would have ratios to suit the revvy nature of the 16V engine. You will have better acceleration away from the lights but noisier and less economical cruising and slower top speed I would think.
