nyek7
temp gauge goes up as soon as ignition is on?
Alright folks I've got 91 corrado g60, as soon as i turn the ignition on it rises to about 80 -90 degree from cold an then rises from ther as it warms up, has any1 had a similar problem or no what my problem could be? Cheers nye
I've had this exact problem for the last year. I've swapped out the relevant sensor and that hasnt solved the issue in my case. I've also swapped the relay that the signal goes through and the clocks. Still the same. I'm thinking its something to do with a break in a wire somewhere.
Thats why I've had the issue for a year! I just dont know where to start with the rats nest of wiring.
In the engine bay at the sensor, that's where the wires get hot/cold and the insulation breaks down and the copper corrodes.
