Wesleyvr6
Major trouble bleeding brakes!
Thanks for the useful responses. I was also advised to leaving a weight or something similar on the brake pedal overnight for a few nights thereby keeping some pressure in the system. Would this actually do anything? If so I'm thinking how exactly to apply the pressure!
You can over bleed them,it puts a lot of micro bubbles in the system.I got mine close,drove it carefully for a week,re-bled it,sorted
I had a nightmare bleeding my brakes but took the advice I got from John at JMR which was just drive it (carefully) and it did sort them out. What I did notice the last time was when I released the air on the Eezi Bleed to refill the brake fluid in the reservoir, it put loads of tiny bubbles into the fluid and I'm not sure if that was one of the causes of my headaches
