lilfuzzer 1 Posted March 3, 2012 Hi peeps in the know Quick question would there be a problem with fitting the twin fans of a vr6 to the front of the radiator? Just wondering as have slimline fans and they seem to fit if I move the current oil cooler just it will give me more room on the short runner piping many thanks in advance :) Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted March 3, 2012 I am not sure, as the fan only really come on when you are stationary, so the hot air from the radiator will be blown into the already hot engine bay, you might see an increase in temperature, the fans would keep pushing warm air against the engine. thats why the fans will nomally be mounted in the inside pushing the warm air out of the engine bay. Quote Share this post Link to post Share on other sites
floppyman 0 Posted March 3, 2012 I am not sure, as the fan only really come on when you are stationary, so the hot air from the radiator will be blown into the already hot engine bay, you might see an increase in temperature, the fans would keep pushing warm air against the engine. thats why the fans will nomally be mounted in the inside pushing the warm air out of the engine bay. ???? The fans push fresh air trough the radiator into the engine not the other way around... For the poster.... If you manage to fit the fans on the outside then maybe wire them around as well so that it pulls fresh air into the radiator Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted March 10, 2012 I stand corrected then Quote Share this post Link to post Share on other sites
