CazzaVR
Breaking Late Spec 2.0 16v Black Interior *Can bring items to Bristol Volksfest*
Do you have the heater control panel ?
I am assuming it has the round dials??
Yes we do - assuming its just the plastic panel you want? - do you need the dials as well?
Patric- will need to look. Should have clips, but don't think we have the scraper.
Peter- mirror's gone, but still have the door if you're interested. It's pretty bare, but still has the window + mech. Wouldn't want much for it...
Definitely interested, can you possibly send me a picture of the door if you have one? Thanks
I don`t need the plastic panel,its actually the rotary controls,cogs etc that i`m after
Got those. The controls work perfectly, but the corner bits where it screws in are broken.
Peachers- no pic yet- will get you one asap :)
How much do you want for it then?
I can strip it and fit the working cogs into my plastic surround !
Good thinking! £15 delivered.
Ok if you still have the drivers side parcel shelf support,I will take that too!
How does £30 posted sound for both??
Yes, got them. The hard lines are great, the rubber ones are starting to perish at the ends. I'd throw in the injectors too if you wanted them.
Money sent
Thanks mate :)
---------- Post added at 7:58 PM ---------- Previous post was at 7:57 PM ----------
Have you got the plastic trim which goes along the back of the headlining?
Number 15 in the pic
Must not have any breaks in it please :)
Yep- think it's in good nick- will have a look for you on Saturday...
Wouldnt happen to have the fuel pump with the attached pipe to the regulator would you???
Last thread was to big, so here's a new one!
Late spec 2.0 16v with black cloth interior, stainless exhaust, sports cat (>£300 when new in 2006) etc etc. Engine runs very, very well. Smooth gearchange with no crunching. Lots of pics to come soon.
We will list parts as we take them off. Please feel free to make requests.
All prices are posted unless otherwise stated Collection welcome!
Interior switches, electrics etc tested and fully working:
Late 16v Clocks (full working order, showing 119K) - £40
Headlight switch - perfect working order, all tabs intact £15.00
Fog light Switches - working order £12.50
Rear Demister switch + blank - working order £10 - SOLD
ABS Light - - working order - £15 SOLD
Spoiler switch - £10
Blank switch face - £5 - SOLD
Rear Boot light - working order - £6.50
Driver's double window switch - £12.50 SOLD
Passenger single window switch - £10 SOLD
Driver's grab handle + mirror switch - £15 SOLD
Interior light & sunroof switch (the bigger 'pull-down' version) - £15
Kenwood W8531 CD/Receiver (50 watts, RDS, AM/FM, Face off, customisable display, remote) - perfect working order - £30 - delivered
ABS Controller - £25
Window control module £20
Assorted relays POA
Central locking pump -with foam and strap if required - £17.50
Interior seats and trim:
Black cloth interior (no hump), good condition, slight driver's bolster wear - £80 - SOLD
Heating vent grills - full set, good condition - £3 each or £10 the lot - SOLD
Sun vizors, good condition, courtesy mirror light working - £22.50
Cigarette lighter and mounting - £8.50
Ashtray and mounting - £5
Black grab handle, good condition - £10 - SOLD
Speedo surround (left corner plastic broken but does not show or compromise a good fit) - £10
Complete seatbelt set - £25
Top of door card plastic trims - both sides - perfect - £25
Passenger side door pull/grab handle - - good condition - £10 - SOLD
Inner Door release surrounds - £7.50/each (Grab a bargain - these are £50 each from VW!) - SOLD
Black Cloth Late Doorcards - good condition 2x front/2x rear - £40
Passenger Interior door triangle - £8
Headlining, standard beigey/grey colour (x2), good condition - £15 ea Collection only please
Sill plastics (both sides) £15
Gear stick surround, gaiter and knob (non standard 'dimpled' gaiter and knob but nice) £15
A-pillar trims (each has one tiny hole where the alarm sensors were mounted): £15 the pair
B-pillar trims: £20 the pair
C-pillar trims: £20 the pair
C-pillar joining trim: £10
All above trims (A, B, C & joiner): £45
Parcel shelf supports inc speakers (VGC):£30 the pair or £17.50 each
Centre tunnel plastics (for 4 cyl cars without rear seat hump) 3 pcs, very good condition, all securing clips present: £20
Rear ashtray: £10
Dashboard- VGC (no holes etc): £40
Engine Bay:
Strut Mount plastic covers - £3.50 Provisionally SOLD
Washer bottle x 2 - £7.50 each
Headlight/airbox plastics (2 bits from between headlight and airbox) - perfect - £10
Throttle body: £20 delivered
Upper manifold: £30 delivered
HT lead holder (all clips present!) + lead puller + clips + brackets: £12.50 delivered
Distributor: £40
Metering head (see post #6), excellent condition (inc rubber/metal fuel pipes, 5 injectors): £40 delivered
Lower airbox (drilled) + warm air hose: £25 delivered
Manifold heatshield + warm air hose attachment: £10
ISV- excellent condition! (oem, looks very recent): £25 delivered SOLD
Fans/Radiator/fan switch/rad cover: £40
Radiator air guides (2pcs): £10
Starter Motor: £20
Slam panel (flash red): £30 collected
Exterior:
Aerial £5
Aerial Base + Gasket - good condition - £12.50
Petrol flap - good condition, no rust, spring intact - £15.00
Fuelling grubber - good condition - £5.00
Rear lights (4pcs, VGC) - £40 SOLD
Headlight - Driver side good condition all tabs etc but very light chipping to bottom of glass £30 SOLD
Headlight - Passenger side - all tabs intact £40 SOLD
Front Indicator - drivers side - 2 very small cracks (see pic) £12.50 SOLD
Front Indicator - passenger side - 1 very small crack not very noticable (see pic) - £12.50 SOLD
Front fog - very good condition SOLD
Front Grill - only has the middle upper tab but holds fine - £12.50 SOLD
Flash Red Corrado script rear badge - good condition (all tabs intact) - £9.50
Bonnet - good, straight condition, could do with a respray - £40 collected
Drivers Door handle and key (fitted with the Dave16v repair kit so won't break again!) - £25 SOLD
Wing Mirrors, good condition (both sides) £20 each
Side mouldings, good condition - full set £30
Passenger side door handle with key - £25
Drivetrain/Brakes/Suspension etc:
OMP rear strut brace (red) - £20
4-stud spacesaver - £25
Misc:
Tool set - £32.50
Document Wallet (inc instruction manual but excluding service book) £12.50
Tailgate gas struts - pair with all fittings in good condition - £20
PM myself or Vornwend with requests.
Yep- still got the fuel pumps. Have you got a pic of exactly what you're after?
