gti gadge
Rallye/golf big FMIC into a Rado
Going to be fitting a rallye/golf big (standard full width job) FMIC to the corrado later this year. I have the U-bend to go with it and the piping. Is the cooler a direct fit, physically? or are mods needed to get it on and in? Any help appreciated. thanks
---------- Post added at 11:25 AM ---------- Previous post was at 11:14 AM ----------
Similar thread section is better than the search function on here! Had a read through some of the stuff on there and looks ok, some trimming needed. Anyone got any info on what trimming is needed to make it fit?
Think you have to trim the plastics on the radiator where the air guides screwed to. And cut a couple of notches in the golf intercooler for the bonnet release cable and to clear the slam panel
depends if you use a golf g60 i/c or rallye. g60 will go in as above, rallye is a little bit longer so you have to cut off the towing eye.
advantage of rallye is being able to use a massive radiator, but imo would go with the g60..
