Benjevw
Where the heck does this go?
Think its for the dim dip resistor that should be located on the front upper part of the wing to the right of the battery there mate. :o
Yup, Dim-Dip connection. Either just disconnected or the Corrado had an uprated headlight loom/relays fitted.
Yea it did have an upgraded loom on it when I got it but I removed it because it was a right mess. I've got another uprated loom now. Do you not need it connected then?
Cheers guys. Not to good wiv leccys.
Don't connect it if your running any upgraded wiring loom buddy, are your lights working and functioning properly?
I haven't fitted the new loom yet , its just original stuff. Yea all lights work properly. Does it just dip the main beam then?
Cheers
It's so when the side lights are on the dipped beam is turned on but really low.
