p0l1wrath
bonnet realese removal
took the front end off the corrado the other day but couldnt seem to get the bonnet release cable undone so had to rest the slam panel on the floor next to the car! Got to take the front end off again on sunday and would like to know how to remove it properly?
had a look around to see if i could find anything on here but everyone either says "remove the bonnet release cable" or "youll see how to do it when your down there?" i couldnt seem to see how to do it? and couldnt find anyway of doing it at all?
im probably just missing something, but would someone be able to tell me how to remove it?
Cheers
By the passenger light there is a trumpet shaped piece with a bolt going through it.
Undo the 7mm bolt and the cable can be released and pulled through the guides.
ok cheers thought i could have been that but it was all rusted and grimed up what is it just a 7mm bolt? or an allen stub screw thing?
That will probably snap when you try to remove it!
already has been :( thats why i was questioning how to do it, gunna be very annoying to remove and tap :( can you get replacements?
