Madjackal 0 Posted May 22, 2012 When I first did an oil change on my last VR I spent half a day trying to get the oil filter housing off, when I did put it back I did it hand tight and never had any subsequent problems. I am now doing my first oil change on the new VR and guess what, it wont budge. I've even snapped my new unused strap wrench trying to do it. Also I hate to say it but the filter was last changed by Stealth of all people! Its such a ballache to get to as well I have a flexible hose and a metal hose running right under the housing so no hope of getting a socket on there, and if it was even just an inch lower it would be so much easier to get to. I'm now stuffed as idiot that I am I drained the oil first so cant run myself up to halfords to get some more tools to break! Damit! Rant over.... Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 22, 2012 You can undo the bracket that holds that flexible hose fella that then gives you the room to get a socket on the end of the housing ---------- Post added at 6:19 PM ---------- Previous post was at 6:16 PM ---------- http://www.corrado-club.ca/mods/vr6_oil_change.html Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 22, 2012 I just punch a long screwdriver through the filter and use that to wrench it off. Always worked when the filter wont budge with a strap/chain wrench. Just prime the filter and put some oil on the seal before refitting to ensure it doesn't happen again. :smug: Quote Share this post Link to post Share on other sites
Madjackal 0 Posted May 22, 2012 I just punch a long screwdriver through the filter and use that to wrench it off. Always worked when the filter wont budge with a strap/chain wrench. Just prime the filter and put some oil on the seal before refitting to ensure it doesn't happen again. :smug: Cant do it that way chap, the filter sits inside a plastic housing that has to be taken off. God only knows why they thought plastic was the best material!! Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 22, 2012 Ah my apologies, I'll get my coat now! Quote Share this post Link to post Share on other sites
