emu 0 Posted June 5, 2012 (edited) All parts are brans new otherwise will add a note. All prices include postage - ABS Pedal position sensor - 100 pounds - Bonnet opening cable - 30 pounds - Eibach Anti Roll Bars VR6 only 22m and 25mm. Kit number E8530-320.They been powder coated black as original paintwork was destroyed in storage. - 275 - D&G Autotech fan brackets - 60 - VR6 Ferrea Oversized Valves +2mm intake & +2mm exhaust - 215 - Fixed steering column parts - 80 -Fuel filter - 15 SOLD Oil filter - 7 - Uprated Headlight loom - 15 - Neuspeed Power pulley set - 150 - Oil filters. First one is longer, no idea why, where there any difference ?? Last two are same size. - 7 posted each or 12 for two or 15 for all 3. - Parcel shelf strap - 15 - R32 Spec Single Mass Flywheel alloy - 230 - Reverse light switch - 6 - VR6 Throttle cable - 30 - Valve cover gasket - 30 - VR6 Hubs - 45 pair - Gaskets top is intake manifold, bottom I believe is a pair of gaskets for exhaust downpipe. 15 each or 25 for both - VR6 only Powerflex complete set of polybushes + one exhaust hanger - 160 - Crank Sensor, receipt says over 80 pounds - 60 Edited June 6, 2012 by emu Quote Share this post Link to post Share on other sites
easypops 8 Posted June 5, 2012 Exhaust manifold gaskets £15 please mate :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 5, 2012 (edited) i'll have the VR6 wheel bearing Sump gasket Thermostat Fuel filter please Edited June 5, 2012 by Jim Bowen greed Quote Share this post Link to post Share on other sites
