JMC
MOT and CAT question for J reg G60...
I know the MOT regs with regards to CAT's have changed recently, however what's people experiences with the older Corrados (pre 93) in real life since these new regs have come in? From memory, if the car was registered before August 92 (which mine is) then it doesn't need to have an emissions test during the MOT. Does the CAT point still apply - mine has not had a VW exhaust from when I owned it so I have no idea whether it had a CAT or not.
Mine was a J reg, with a cat bypass, and I had no problems at all with the MOT. I think up to a J reg you're OK and after that, not!
Anything on a j or earlier doesn't need a cat.
I miss this by 4 days :@ and am on a k plate.
Although a friendly mot man may let it slide
Thanks guys, I sort of thought that would be the case, but wanted to check. Gutted for you Owen :( that sucks. Fingers crossed...
