KADVR6 0 Posted July 7, 2012 what is the best and easiest way of fitting them, as can't seem to get hold of the correct vw tool from anywhere. Karl Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted July 7, 2012 I'd only advise on using the VW tool to avoid damaging / breaking the rings. Quote Share this post Link to post Share on other sites
KADVR6 0 Posted July 7, 2012 i do hear what your saying Pete, but was told by vw that they are not available anymore? Quote Share this post Link to post Share on other sites
DJstitch91 10 Posted July 7, 2012 do you mean for getting the rings onto the piston? or piston and rings into the bore? Quote Share this post Link to post Share on other sites
science 0 Posted July 7, 2012 I made a teflon wedge with a 7.5 degree slope to allow use of a normal piston ring compressor. I'll post a photo if your interested. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted July 8, 2012 Hi Karl is it for putting the rings on the piston? if so there are some special pliers to open them up or use some bent long nosed pliers and cut a slot on the back edge If its for the pistons back into the block correct no longer for sale from VW as when I bought mine they said it was the last one. If you want I could post it to you to lend if you like? Quote Share this post Link to post Share on other sites
KADVR6 0 Posted July 8, 2012 Chris that would be amazing if you could, i will happily pay postage and any other costs mate. this is what this forum is about, and im gonna miss this if i do sell the car. Quote Share this post Link to post Share on other sites
dannyboy 0 Posted July 12, 2012 http://www.ebay.co.uk/itm/Universal-piston-ring-pliers-suitable-piston-rings-50-100mm-2-3-15-16-/350578628704?_trksid=p3284.m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D21%26pmod%3D120703530121%26ps%3D54 Try these mate,theyre the correct tool and dont cost much Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 12, 2012 (edited) Remember you don't want the ring gaps on the thrust faces Karl and before you put a piston assembly anywhere near the tool, absolutely drench it in oil first. Get a lunchbox, fill it with oil, then dunk the piston assembly in it first...... might be worth sliding an old piston in and out several times first :D Those VW plastic funnels can be a pain and if you snag a ring on it, hmmmmm, it's usually game over. Edited July 12, 2012 by Kevin Bacon Quote Share this post Link to post Share on other sites
