Brian_B
Engine Wanted!!
Just blown the G60 engine (PG Code) in my Caddy and looking for something else, will a VR6 engine drop straight in??
If anyone has anything that'll go, please drop me a message and let me know along with the details and price.
Much appreciated :)
Brian
Lion, would it drop straight in or would I need to modify anything?
Could you pallet it for me so I could arrange a courier?
Thanks
Brian
I've got a good runner VR6 but it's far from plug and play into a G60.
Let me know if you're interested.
I think the mounts are in different locations arent they? Plus you'd need to upgrade the brakes, gearbox (??), front suspension, ECU and Looms etc. But it is possible.
Here's the spec of what's on the van just now:
Gasflowed big valve head
Schrick 272 degree cams
Front mount alloy intercooler
68mm pulley
G-Werks chip
Pipercross panel filter
Schrick baffled sump
Gasflowed exhaust manifold
New s/s exhaust
G60 Disc & Pads with Audi S2 twin pot calliper
V-maxx front coilovers
Axle flipped with boge turbo beetle shocks
Recent Stage 4 Supercharger Rebuild by Jabbasport
To be honest I've not stripped the head back to see what the damage is...won't get round to it til the weekend. I'm really needing a quick(ish) fix to get it back on the road....Looks like either a repair or a straight swap would be best for me depending on what I find. I'm hoping that it's just the head gasket but as we all know it can be a lot worse than that once I crack it open. It'd be a shame to drop this engine out because it's had a hell of a lot of work done to it but I just don't have the time or indeed a couple of grand to start throwing at it just now unfortunately! Just done a quick compression check and here's what I got... cyl 1 - 100psi cyl 2 - 60psi cyl 3 - 85psi and cyl 4 -100psi. Need to get a look at the Bentley when I get home to see what they should be at....I'm hoping that just the gasket has gone between 2 & 3 but I'm no mechanic so I'll get the old boy to cast an expert eye over it.
Edited by Brian_B
There's a freshly rebuilt 16v G60 with 0 miles for sale on E38. Approx £2.5k if I recall but he's open to offers.
