VR-Sixy 0 Posted August 19, 2012 Morning people, does anyone know if it's possible just to remove the top of the slam panel? I've just bough a new pair of headlights and the left one is in without any problem, but the right one will not budge. I wonered if you can remove the top of the slam panel so i could possibly get to the errant headlight a little easier? Or, is it as i think it is and that it's all one piece and can only be taken out whole? Ta Muchly. :D Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 19, 2012 Hi mate. You can't I'm afraid. Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 19, 2012 Your not forgetting the screw for the light that requires a long screwdriver down the hole in the slam panel are you? Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted August 19, 2012 Your not forgetting the screw for the light that requires a long screwdriver down the hole in the slam panel are you?Possibly, i didn't get that far. When i changed the R/H headlight, i came out without having to touch that other screw. But i'll take another look next weekend..... when i've found a long enough screw-driver!! :D Quote Share this post Link to post Share on other sites
Stonejag 10 Posted August 20, 2012 When they're changed the third screw is often not refitted - it tends to corrode and get stuck. Swap it for a new one once you remove it, or leave it out :) Stone Quote Share this post Link to post Share on other sites
