borders16v 0 Posted October 3, 2012 Hi. Can anyone tell me where i can get a pair of droplinks that will sort my 2.0 16v out. Had mine done a while back and the ride quality plummeted and the tyres wore badly also. Obviously dealer is the place to go but at nearly 100 quid its just too much. Ecp quoting 9.70 for q-line brand.Are these any good? Thanks for any suggestions. Quote Share this post Link to post Share on other sites
timthetinyhorse 0 Posted October 3, 2012 Is this car on stock suspension? fail to see how new droplinks could destroy tyres......did you have the alignment checked after doing the work? Quote Share this post Link to post Share on other sites
borders16v 0 Posted October 3, 2012 Standard suspension.Was all good until droplinks were changed for mot.Outer wear has been severe since.Didnt get realign check done as it went smoothly last time these were done by the same guy years ago. The ride has been lousy since,tyres move badly sideways over minor bumps and really skitish in the wet. Quote Share this post Link to post Share on other sites
timthetinyhorse 0 Posted October 3, 2012 all seems a bit weird that the ride is poor since fitting aswel, have you had a look under the car? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 3, 2012 (edited) I personally wouldn't use anything but VAG but if you are going to buy pattern then I'd get these... (BTW - VW charge about £30 each so not sure where £100 came from?) http://www.vwspares.co.uk/product_info.php?products_id=741 Edited October 3, 2012 by Supercharged Quote Share this post Link to post Share on other sites
James. 9 Posted October 3, 2012 (edited) Sounds like track rod ends to me. I had a similar issue recently. I changed everything on the front except for the t/r ends. Tracking was way out and hopping around dangerously. Changed the t/r ends and once laser aligned is now driving the best I've ever had it. I get mine from a chap off ebay "tierod69". German parts and so far seem good quality. Edited October 3, 2012 by James. Quote Share this post Link to post Share on other sites
jamiehamy 0 Posted October 3, 2012 You may well find that someone in their wisdom disconnected something to make it easier to fit the droplinks. I wouldn't, but you never know. Say they disconnected the hub from the strut to let the wishbone move easier, and jsut flung back together, your camber will be all over the place, and the tracking by default. def worth checking. Quote Share this post Link to post Share on other sites
borders16v 0 Posted October 3, 2012 (edited) Cheers guys,will check out tracking before buying more drop links then.Should haves said the wishbones were done at the same time so maybe the lots messed up? Oh what fun Edited October 3, 2012 by borders16v Quote Share this post Link to post Share on other sites
jamiehamy 0 Posted October 3, 2012 Tracking absolutely most definetly will be messed up then! make sure you take it somewhere that can do camber - without camber being right, they can track all day and you'll still chew tyres. Good luck! Quote Share this post Link to post Share on other sites
timthetinyhorse 0 Posted October 4, 2012 Thought there would be more to this story than just droplinks............... Quote Share this post Link to post Share on other sites
