XM4RTYX
Fully working sunroof motor
As above, I'm after a fully working sunroof motor, as mine only works on tilt
95' model
Thanks
Edited by XM4RTYX
95' model
Thanks
Fitting a new motor will probably not cure the problem, its more likely to be a snapped cable, passenger side I would suspect
I would agreed with billcor here mate as usually the mechanism failure
What do you mean haha? Fancy seeing you on here anyway! Haha! Think it could be motor though! As it does work on tilt, and it does go back so far too, but then gives up! Also it goes all the way back and closes no problem, when doing it manually! So don't think it's wires/cables
yea same symptoms as mine...turned out to be a tired motor
managed to nab one off a mk3 at the scrappies
best rule that out before stripping the headlinning etc etc..
Remember to resynchronise your motors before refitting them to the sunroof folks.
1) Leave the roof in it's closed position
2) Connect replacement motor to the loom
3) get out of car and operate the full closure
4) observe the motor turn then stop
5) Motor is now happy where up, down, back and forward are and refit to the sunroof.
If you don't do this, the motor will basically keep going when you slide it back until it crunches into something, or won't tilt properly, won't close properly etc etc.
Thanks for that Alan and Kevin! Full closure no long works off fob, as I had to disconnect the alarm and awaiting a new one, but is it ok to do it by the key in the door lock Kevin?
Thanks
Lmao
I've got a motor you can try if you want before you buy one mate, I'm not selling it though cos I'm gonna put it in the VR with the moonroof I think
Just drop me a pm if you wanna pop over one day to try it
Lmao
Thanks for that Chris, I have already paid somebody and just waiting or it to get delivered now! Thanks anyway mate! Are you at meet tomorrow?
